[GRASS-dev] Re: [GRASS-user] r.contour "level" attribute
Moritz Lennert
mlennert at club.worldonline.be
Fri May 16 13:25:59 EDT 2008
On 16/05/08 17:26, M S wrote:
> Hi everyone.
> I had generated some contours from a DEM with r.contour. In the
> resulting vector contour map, I get cat and level, where level is the
> elevation value. I must be confused with the level terminology, because
> I thought levels pertained to topological (2) or non-topological data
> (1). However, in r.contour output, "level attribute" corresponds with
> the contour elevation.
In GRASS the same words sometimes have different meanings according to
context. Generally for historical reasons...
> Regardless, I'm able to query the lines in GRASS monitor to get the cat
> and level (elevation) values for the contour lines, but in QGIS I'm
> unable to query or identify the features. In QGIS, I am able to label
> the lines on the "level" item though.
> I refrained from cross posting to QGIS list, because it seems like
> something I'm not understanding in GRASS vector model.
> Any ideas why the features are (repeatably) unidentifiable in QGIS, but
> are viewed and labeled without issue?
No idea, but I can confirm with the North Carolina demo data:
- elev_contour_3m: no data found
- any other line layer (streams, busroutesall, etc): I get the relevant info
After a bit of testing, it seems to me that this is due to the fact that
the contour lines have 3D points as vertexes, i.e.:
v.out.ascii elev_contour_3m format=standard
L 309 1
644845.39132067 228495 58
644850.5257363 228485 58
644855 228476.80568172 58
644856.10080552 228475 58
whereas the others have 2D points as vertexes, i.e.:
v.out.ascii busroutesall format=standard
L 40 1
638759.35668041 224267.86790137
638748.56434918 224206.16089597
638738.04094476 224149.69241332
638701.95659054 224155.1582149
638712.48508636 224219.60539241
638727.41956522 224217.30778103
638737.10320251 224271.95933017
So it seems to me that this is a flaw in QGIS' handling of this type of
data.
Moritz
