[GRASS-dev] R: [GRASS-PSC] SVN Write Access Request
Marco Pasetti marco.pasetti at alice.it
Sat May 17 04:32:27 EDT 2008
Hi Hamish,
>> 2) branches/develbranch_6/win32
>> the folder where i put all the scripts and files needed to prepare the
>> release installer (as an exe file).
>why refer to 32bit in the dirname?
Good question; actually I named it as I'm used in my windows projects,
because I build on a 32 system;
BTW, I don't know if MSYS/MinGW + NSIS are available even for Win64...
For me it's the same... We can call it just "Windows"
>> Just few questions: all the files (dos batch scripts, the NSIS script,
>> icons and documents) are made by me, with the exception of:
>> 2.1) the bmp files (4) for the installer GUI, taken from the standard
>> library of NSIS (that is OS, obviously)
>it may be "open source", but that means 1001 different things, many of
which we can not touch. what is the license exactly? are those 4 files
distributed under terms
>compatible with the GPL? If not GPL is it one of the OSI usual-suspects
approved set?
>From the NSIS official web site:
Applicable licenses
* All NSIS source code, plug-ins, documentation, examples, header files and
graphics, with the exception of the compression modules and where otherwise
noted, are licensed under the zlib/libpng license.
* The zlib compression module for NSIS is licensed under the zlib/libpng
license.
* The bzip2 compression module for NSIS is licensed under the bzip2 license.
* The lzma compression module for NSIS is licensed under the Common Public
License version 1.0.
zlib/libpng license
This software is provided 'as-is', without any express or implied warranty.
In no event will the authors be held liable for any damages arising from the
use of this software.
Permission is granted to anyone to use this software for any purpose,
including commercial applications, and to alter it and redistribute it
freely, subject to the following restrictions:
1. The origin of this software must not be misrepresented; you must not
claim that you wrote the original software. If you use this software in a
product, an acknowledgment in the product documentation would be appreciated
but is not required.
2. Altered source versions must be plainly marked as such, and must not be
misrepresented as being the original software.
3. This notice may not be removed or altered from any source distribution.
About the above mentioned terms:
1. done:
http://grass.osgeo.org/grass63/binary/mswindows/native/#Install%20GRASS
2. I didn't altered the source, I'm using only the binaries
3. We are not distributing the source code
>> 2.2) a small part of the installer, a function to let replace parts of
>> strings; I just copied and pasted it, maintaining the header, where is
>> clear the line ";Written by [author]"
>what license terms did the author provide it with? you can not just cut and
paste things from the internet or "cook books", even with attribution. is it
a simple
>one-liner that is hard to write any other way, or is it an original work?
without a clear license you can not distribute the code.
I found it on the wiki/examples section of NSIS site
http://nsis.sourceforge.net/StrRep
Since it's an example it lays in the zlib/libpng license mentioned  above.
In particular, as I didn't modified the code, it respects all the terms in
it.
>if in doubt try and contact the author of that code, they may give you full
permission to use, modify, and redistribute it.
The contact page of the author [http://nsis.sourceforge.net/User:Dandaman32]
is no more available.
>good reading:
http://www.softwarefreedom.org/resources/2008/foss-primer.html
Thanks ;-)
Marco
-----Messaggio originale-----
Da: Hamish [mailto:hamish_b at yahoo.com]
Inviato: giovedì 15 maggio 2008 12.54
A: grass-psc at lists.osgeo.org; marco.pasetti at alice.it
Oggetto: Re: [GRASS-PSC] SVN Write Access Request
Marco:
> I read and accepted the terms of the RFC 2 document published here:
> http://download.osgeo.org/grass/grass6_progman/rfc/rfc2_psc.html
ok, then "+1" from me.
> > simple curiosity: where do you expect your initial
> WinGRASS commits to be? In a dir in the source code like macosx/ and
> debian/, or in the grass-web grass63/binary/mswin/ area, or ..?
> 1) grass-web/trunk/grass63/binary/mswindows/native
> to maintain the published release documentation
it may be "open source", but that means 1001 different things, many of which
we can not touch. what is the license exactly? are those 4 files distributed
under terms compatible with the GPL? If not GPL is it one of the OSI
usual-suspects approved set?
a simple one- liner that is hard to write any other way, or is it an
original work?  without a clear license you can not distribute the code. if
> does it match the RFC 2?
Without more details I don't know.
to be clear, it is explicitly the committer's responsibility to ensure that
everything they put in the repo is legally kosher.
(this is perhaps a matter that should be cc'd to the -dev list for wider
audience + comment)
good reading:
Hamish
