[GRASS-dev] Vect_line_buffer tolerance setting
Hamish
hamish_b at yahoo.com
Sat May 17 19:44:34 EDT 2008
Maris:
> I was going to use Vect_line_buffer function but was unable to
> understand it's tolerance parameter. Could somebody
> extend a bit documentation to make it more clean what does it mean.
I am not 100% sure,
> For my module I need to create buffer around line without any "round
> caps" at line end -> buffer must look like square and not extend
> beyond input line end. Ideas how to tweak tolerance setting
> to get such functionality out of Vect_line_buffer?
maybe 'v.parallel distance=' for both left and right side of line?
or v.segment / v.lrs.segment with offset.
Hamish
