[GRASS-dev] Re: [GRASS GIS] #138: PNG_driver: boundary at right
side is one Pixel off
trac at osgeo.org
Sun May 18 20:01:48 EDT 2008
#138: PNG_driver: boundary at right side is one Pixel off
Reporter: schulzea | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords: PNG_driver
Comment (by hamish):
d.out.file is another method to test.
All d.out.file and d.out.png do is setup and run the PNG driver for you.
you could try setting:
export GRASS_TRANSPARENT=TRUE
before running d.out.png if you want it to have transparency.
> I use grass 6.2.2 under Ubuntu.
can you test to see if it is still there in 6.3.0?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/138#comment:3>
