[GRASS-dev] dealing with nan
Yann Chemin
yann.chemin at gmail.com
Mon May 19 05:01:01 EDT 2008
2008/5/19 Hamish <hamish_b at yahoo.com>:
> > Yann Chemin wrote:
> > > I have some data that reads as "nan", while
> > > rare, it may happen when compressing/uncompressing
> > > GRASS Locations to ship them across Internet.
> what method are you using to compress/decompress?
> ..zip? .tar.gz? r.pack/r.unpack?
Windows zip, ftp download across the World, then Linux unzip.
> if r.pack I think it is safer to use the script in the trac wish patches
> which converts GRASS <=6 raster dir layout to proposed GRASS 7
> $MAPSET/raster/$NAME/element) then tarball up the map's dir, and vice versa.
> I should probably update r.pack not to use r.{in|out}.mat as that will lose
> some metadata for sure.
We will use r.[,un]pack that from now on.
> places in the code to look for accidental creation of nan:
> - (x/y) where both the x and y variables could sometimes be 0.
> - tan(pi/2)
> - r.in.mat/r.out.mat use Matlab's NaN to store grass NULLs
> - GRASS nulls + non-core libgis functions meet mixed endian (?)
hmm, tan() is a suspect here. x==y==0 may also be, shall put tests but more
complex.
> > > I would like to know how to deal with them in GRASS
> > > raster programming, so that they are:
> > > 1 - detected
> > > 2 - set to null
> Glynn:
> > if (x != x)
> > G_set_d_null_value(&x, 1);
> > There is also isnan(), which is in C99, and also specified
> > by POSIX:
> > http://www.opengroup.org/onlinepubs/009695399/functions/isnan.html
> > However, I don't know if it exists on all platforms
> > which we care about. MSDN says that MSVCRT has _isnan() (with a
> > leading underscore), but it's defined in <float.h> rather than
> > <math.h>.
> > The (x != x) test should be portable; OTOH, it's the
> > kind of thing that compilers often get wrong, particularly when
> > optimising (if you ignore NaN, x!=x is always false).
> there is a longstanding wish that 'r.null setnull=' could understand nan,
> so that you could get rid of them. e.g. very rarely r.in.xyz will create
> them, I am not sure why/how.
would be useful to make coloring of output maps appear... right now nan
intefers in the standard colors setup, it seems.
> > For 7.0, I intend to change G_is_[fd]_null_value() to treat
> > all NaN values as null, not just the specific bit patterns which
> > it currently uses.
> the only reason I could see to keep them as nan not grass-NULL would be for
> debugging (there is obviously a bug if you get them..).
> Hamish
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080519/0a0011b2/attachment.html
