[GRASS-dev] Re: [GRASS GIS] #165: compilation error
Glynn Clements
glynn at gclements.plus.com
Mon May 19 05:17:35 EDT 2008
> Reporter: watti | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: closed
> Priority: major | Milestone: 6.3.1
> Component: default | Version: 6.3.0
> Resolution: invalid | Keywords:
> Changes (by neteler):
> * status: new => closed
> * resolution: => invalid
> Comment:
> See also GRASS' INSTALL file "(C) COMPILATION NOTES for 64bit platforms"
> grep fPIC INSTALL
> FFTW2 library has to be compiled with -fPIC flag:
> CFLAGS="-fPIC" ./configure
> Closing.
It might be worth adding a "task" for enhancing the build system to
better support static libraries.
[Or we could just refuse to support static libraries. I have no idea
why RHEL's FFTW is a static library.]
On Unix, you could make a non-PIC libfftw.a work by adding -lfftw to
each executable which uses the gmath library, and removing it from any
commands for linking shared libraries.
Adding $(FFTWLIB) to the value of GMATHLIB and removing it from the
EXTRA_LIBS setting in lib/gmath/Makefile would almost work, except
that:
1. $(GMATHLIB) is included in the definition of EXTRA_LIBS in
lib/rst/interp_float/Makefile and vector/lidar/lidarlib/Makefile, so
you would run into the same problem when building those libraries.
2. It doesn't work on Windows, where dependencies have to be satisfied
when the shared library is built. You can't omit dependencies and
leave it to the executable to satisfy them (ISTR that there are ways
to do this, but they're quite messy, and require everything to be
spelled out in detail).
To get around this, you would need to split each *LIB variable into
two versions, one for shared libraries and one for executables. Static
libraries (which normally don't contain PIC) would only be added to
the "executable" version.
