[GRASS-dev] Re: [GRASS GIS] #174: Unable to create file [REF] for
subgroup [sub-test] of group [test in neuba]
trac at osgeo.org
Tue May 20 02:48:26 EDT 2008
#174: Unable to create file [REF] for subgroup [sub-test] of group [test in
neuba]
Reporter: neuba | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: duplicate | Keywords:
Changes (by neteler):
* status: reopened => closed
* resolution: => duplicate
Comment:
You indicate a problem of i.class which is discussed in #70. i.group
should work (please check the directory directly: the file will be
present). But i.class does not find it due to a bug in
I_fopen_sigset_file_new() in lib/imagery/sigsetfile.c. Let's continue in
#70. G_fopen_new_misc() therein is failing.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/174#comment:3>
