[GRASS-dev] [GRASS GIS] #175: v.to.rast labelcol= SegFault
trac at osgeo.org
Tue May 20 08:56:14 EDT 2008
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: v.to.rast |
v.to.rast segfaults with the labelcolumn= option:
#spearfish
G64> g.region -d
G64> v.to.rast in=fields out=fields.v2r labelcol=label col=cat
WARNING: Area without centroid (may be OK for island)
Converted areas: 65 of 65
Converted points/lines: 0 of 0
Segmentation fault
gdb:
#0 0xb791ef43 in strcpy () from /lib/tls/i686/cmov/libc.so.6
#1 0xb7f91793 in set_string (x=0xbf81d978, s=0x808c450 "\"NO DATA\"",
copy=1)
at string.c:108
#2 0xb7f91681 in db_set_string (x=0xbf81d978, s=0x808c450 "\"NO DATA\"")
at string.c:39
#3 0xb7f91a1c in db_copy_string (dst=0xbf81d978, src=0x808c3a0)
at string.c:237
#4 0xb7f9276c in db_copy_value (dst=0xbf81d968, src=0x808c390) at
value.c:372
#5 0xb7efba1b in db_select_value (driver=0x808b2a0, tab=0x808af08
"fields",
key=0x808af18 "cat", id=0, col=0x8057d88 "label", val=0xbf81d968)
at select.c:195
#6 0x0804c571 in update_labels (rast_name=0x8057d78 "fields.v2r",
vector_map=0x8057d68 "fields", field=1, label_column=0x8057d88
"label",
use=1, val=1, attr_column=0x8057d98 "cat") at support.c:298
#7 0x0804d369 in vect_to_rast (vector_map=0x8057d68 "fields",
raster_map=0x8057d78 "fields.v2r", field=1, column=0x8057d98 "cat",
nrows=4096, use=1, value=1, value_type=1, rgbcolumn=0x0,
labelcolumn=0x8057d88 "label", ftype=67) at vect2rast.c:212
#8 0x0804b1f7 in main (argc=7627107, argv=0xb79e2510) at main.c:135
Also when trying to use the vector cat for the raster cat the labelcolumn
is ignored:
G64> v.to.rast in=fields out=fields.v2r labelcol=label use=cat
[success]
G64> r.category fields.v2r
1 Category 1
2 Category 2
3 Category 3
4 Category 4
5 Category 5
6 Category 6
7 Category 7
ie the labelcolumn= is replaced by "Category n"
G64> v.db.select fields | head
cat|label
0|"NO DATA"
1|"C. Smith #1"
2|C. Smith#2
3|P. Biggam#1
4|P. Biggam#2
5|P. Biggam#3
6|P. Biggam#5
7|P. Biggam#6
8|P. Biggam#7
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/175>
