R: [GRASS-dev] Locking is not supported on Windows
marco.pasetti at alice.it
Wed May 21 05:46:39 EDT 2008
thanks to all for the exhaustive replies.
>Are you sure? AFAICT, etc/lock should always succeed on Windows, i.e.
>it won't stop you from having two sessions with the same current
>mapset. You will get a warning, but the mapset should still be
>changed.
sorry but not. I tried to find out why here http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/general/g.mapset/main.c but I still don't know many things in GRASS code to understand it well (and my C is very very rusty). I just found that at lines 155-156 a conditional calls G_fatal_error if the GIS_LOCK env var is not set (var retrieved at line 154).
>If g.mapset doesn't work, you can always change the GISDBASE,
>LOCATION_NAME and MAPSET variables directly with g.gisenv.
Yes, it doesn't produce errors, but it doesn't change the location/mapset!
Marco
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080521/8387ee05/attachment.html
