[GRASS-dev] v.overaly - slow
Jachym Cepicky jachym.cepicky at gmail.com
Fri May 23 12:39:40 EDT 2008
I need to split one big vector file (200MB Shapefile) to several
smaler tiles , so it is more usable for mapserver, and I wrote a small
script v.mktiles, which should split big vector file into several
tiles (attached):
Description:
 Splits large vector map into several tiles with associated attribute table
Keywords:
 vector, tiles
Usage:
 v.mktiles [-c] input=name [type=string] prefix=name columns=value
   rows=value [--overwrite] [--verbose] [--quiet]
Flags:
  -c   Make a copy for attribute table for each tile
 --o   Allow output files to overwrite existing files
 --v   Verbose module output
 --q   Quiet module output
Parameters:
    input   Name of input vector map
     type   Input map type
            options: line,area
            default: line
   prefix   Prefix for output vector maps
  columns   Resulting number of columns
            default: 2
     rows   Resulting number of rows
            default: 2
When the input file is relatively small (spearfish roads), it works fine:
GRASS> v.mktiles in=roads pref=cest columns=2 rows=2 type=line --o
but when I try to run it on file with 155754 isolines, it took an
hour, and even the first tile was not generated
so, my question: is there such script already (maybe something in
GDAL/OGR package, which I missed)? Isn't there any big mistake in my
script?
If desired, in the future the script should take output from v.mkgrid as well
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080523/21fcc1af/v.obj
