[GRASS-dev] Re: proper v.parallel behavior on strange input
Росен Матев r.matev at gmail.com
Mon May 26 08:33:09 EDT 2008
v.parallel outputs strange things, given such input.
v.in.ascii -n format=standard output=test1 input=test1.txt
test1.txt:
L 6
600000.00000000 5670020.00000000
600030.00000000 5670020.00000000
600030.00000000 5670050.00000000
600040.00000000 5670050.00000000
600040.00000000 5670000.00000000
600080.00000000 5670000.00000000
v.parallel input=test1 output=test1_par7 distance=7
On Mon, May 26, 2008 at 3:02 PM, Росен Матев <r.matev at gmail.com> wrote:
> Hello,
> I'm currently reimplementing v.parallel/v.buffer. There are some
> strange inputs with no apparent behavior. Please suggest what should
> v.parallel do on such inputs.
> I've attached a simple input. Try to make a parallel line on right
> side of the given line; distance is greater than 5m (let's say 7m).
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080526/c6606d61/testing-0001.png
