[GRASS-dev] proper v.parallel behavior on strange input
Marco Alicera
marco.alicera at gmail.com
Mon May 26 16:14:18 EDT 2008
IMHO, the wolf`s approach is the good one, since the 'proper'
parallel line must be choosen by users.
i prefere it because it is flexible and can be very fast if there is
no need to remove the loop or no loop are expected.
marco
2008/5/26, Росен Матев <r.matev at gmail.com>:
> Hi Wolf,
> The thing that bothers me is the upper line segment of the loop. It's
> parallel to the corresponding segment of input line but it's direction
> is the opposite. That is quite "non-algorithmic".
> By the way, I'm pretty sure that I figured out an algorithm, which
> will create 'proper' parallel line s (without loops as in Wolf's
> non-dashed example). Unlike the old method of creating parallel lines
> with loops and then cleaning the mess, my algorithm works in one
> piece. (I think the old method doesn't work because you cannot remove
> the loops properly by only using the line-with-loops itself)
> Rosen
> On Mon, May 26, 2008 at 9:15 PM, Wolf Bergenheim
> <wolf+grass at bergenheim.net> wrote:
> > Hi!
> > IMHO it should loop back, and by default the loop should be detected and
> > removed. An option to not remove the loop could be cool.
> > See attached image. The part that should be removed is drawn with a dashed
> > line.
> > --Wolf
> > On 26.05.2008 15:02, Росен Матев wrote:
> >> Hello,
> >> I'm currently reimplementing v.parallel/v.buffer. There are some
> >> strange inputs with no apparent behavior. Please suggest what should
> >> v.parallel do on such inputs.
> >> I've attached a simple input. Try to make a parallel line on right
> >> side of the given line; distance is greater than 5m (let's say 7m).
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> > <:3 )---- Wolf Bergenheim ----( 8:>
