[GRASS-dev] Re: [GRASS GIS] #178: g.copy/g.rename help message
trac at osgeo.org
Thu May 29 12:30:49 EDT 2008
Reporter: hcho | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Comment (by glynn):
Replying to [ticket:178 hcho]:
AFAICT, this is a limitation of the parser. The syntax of the various
options is <old>,<new> but the parser doesn't allow multiple ->gisprompt
settings.
BTW, neither the terminal interactive mode nor the GUI understand the
significance of the key_desc option.
I doubt that this can be changed given the current parser interface and
the way that g.copy/g.rename use it. Essentially, trying to use a single
option for multiple purposes (e.g. both input and output) tends to fail
for alternate modes (--help, --ui, etc).
The only way to make this work with the current parser interface would be
to have separate source and destination options for each type, with the
source labelled "old" and the destination labelled "new".
It would be nice to maintain a global list of cases which the parser
doesn't handle well (or at all), for reference when we get around to
designing a new type system for the parser.
Ticket URL: <http://trac.osgeo.org/grass/ticket/178#comment:1>
