[GRASS-dev] GRASS 7 development started
Glynn Clements
glynn at gclements.plus.com
Thu May 29 12:41:59 EDT 2008
Glynn Clements wrote:
> Two people (myself, Paul) supported -bl (opening brace on line after
> if/for/while), while two (Hamish, Ivan) favoured -br (opening brace on
> same line). Does anyone want to cast the deciding vote here?
Okay, two more votes (Markus, Martin) for -br, so we arrive at:
indent -bad -bap -bbb -br -bli0 -bls -cli0 -ncs -fc1 -hnl -i4 -l79 \
-nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
-npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut
Any final comments before the entire source tree is reformatted?
