[GRASS-dev] Installation of GRASS on Fedora 9
Glynn Clements
glynn at gclements.plus.com
Fri May 30 16:13:02 EDT 2008
Juan Diego Giraldo Osorio wrote:
> I have two pc: the firts with fedora 8, and the another one with fedora
> 9. In the fedora 9 pc I have installed GRASS 6.2.3 in the fedora 8 pc,
> without problems (except by the gdal install circular problem which is
> explained in http://www.kyngchaos.com/wiki/macosx:build:gdal). Now,
> GRASS is running in the fedora 8 pc without problems.
> In the fedora 9 pc I have had problems with the gdal-1.4.1 install. The
> error report is the next:
Problems with GDAL should be reported to the GDAL developers, either
on the mailing list, IRC channel, or bug tracker. Details are at:
http://www.gdal.org/
