[GRASS-dev] Re: [GRASS GIS] #248: v.info vs. r.info: different region output formats
GRASS GIS trac at osgeo.org
Sun Nov 2 02:36:40 EST 2008
  Reporter:  sebastianh   |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  v.info, r.info, region output
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 Replying to [comment:2 martinl]:
 > BTW in GRASS7 I would like to add shell script style output for
 > r/v.info.
 ? don't we already have that in GRASS 6.x from lots of flags?
 > To follow standard flag naming, this flag should '-g' which is
 > now reserved for "Print map region only" (which could be
 > renamed to '-r'.) ?
 -g is used across modules more generally to mean "output in shell script
 style"; albeit usually (but not always) to do with region bounds. (eg
 r.univar)
 As '-r' works quite nicely for "range" (IMO) I don't see the need for a
 change. As long as we are consistent it is quickly learned.
 2c,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/248#comment:8>
