[GRASS-dev] [GRASS GIS] #354: v.out.ogr: bad DB read for format=GPX
trac at osgeo.org
Sun Nov 2 05:22:03 EST 2008
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Keywords: v.out.ogr GPX | Platform: Linux
Cpu: x86-32 |
this is moved from gdal bug # 2638
http://trac.osgeo.org/gdal/ticket/2638
GPX format is not reading the DB table correctly, then filling in the
category number as the elevation.
It works ok using ogr2ogr:
# Spearfish dataset:
# export shapefile
v.out.ogr in=archsites type=point dsn=archsites.shp
# get PROJ.4 params of current location (Spearfish=UTM 13N)
IN_PROJ=`g.proj -jf`
ogr2ogr -f GPX -dsco GPX_USE_EXTENSIONS=YES \
-a_srs "$IN_PROJ" -t_srs EPSG:4326 \
output.gpx archsites.shp
result:
<?xml version="1.0"?>
<gpx version="1.1" creator="GDAL 1.5.0" xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instan
ce" xmlns:ogr="http://osgeo.org/gdal"
xmlns="http://www.topografix.com/GPX/1/1" xsi:schema
Location="http://www.topografix.com/GPX/1/1
http://www.topografix.com/GPX/1/1/gpx.xsd">
<wpt lat="44.381771718385657" lon="-103.826359511024279">
<extensions>
<ogr:cat> 1</ogr:cat>
<ogr:str1>Signature Rock</ogr:str1>
</extensions>
</wpt>
<wpt lat="44.456408157151380" lon="-103.844259647363543">
<extensions>
<ogr:cat> 2</ogr:cat>
<ogr:str1>No Name</ogr:str1>
</extensions>
</wpt>
<wpt lat="44.447669817618234" lon="-103.870697678751810">
<extensions>
<ogr:cat> 3</ogr:cat>
<ogr:str1>Canyon Station</ogr:str1>
</extensions>
</wpt>
slight issue: cat number (column type integers) get padded?
but using GRASS's 'v.out.ogr format=GPX' (via v.out.gpsbabel script) I
get:
v.out.gpsbabel -w in=archsites out=archsites.gpx where="cat < 4" --verbose
Extracting data ...
Reprojecting data ...
Exporting data ...
WARNING: No attribute table found -> using only category numbers as
attributes
Cleaning up ...
Fast exit.
(but there is an attribute table found, otherwise SQL where= query
would fail in the v.extract step)
and output:
XMLSchema-instan
<wpt lat="44.381755779999999" lon="-103.826838609999996">
<ele>1</ele>
<extensions>
</extensions>
</wpt>
<wpt lat="44.456392070000000" lon="-103.844739759999996">
<ele>2</ele>
<extensions>
</extensions>
</wpt>
<wpt lat="44.447653719999998" lon="-103.871178959999995">
<ele>3</ele>
<extensions>
</extensions>
</wpt>
</gpx>
So it's a v.out.ogr bug I guess. I tried copying the vector into the
current mapset from PERMANENT, but it didn't help.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354>
