[GRASS-dev] Re: [GRASS GIS] #354: v.out.ogr: bad DB read for format=GPX
GRASS GIS trac at osgeo.org
Sun Nov 2 05:36:23 EST 2008
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Vector  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  v.out.ogr GPX
  Platform:  Linux   |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:1 hamish]:
 > also to note diff in lat/lon in above two examples:
 > <wpt lat="44.381771718385657" lon="-103.826359511024279">
 > <wpt lat="44.381755779999999" lon="-103.826838609999996">
 > I don't really know why that is different. Both ogr2ogr and
 > m.proj (cs2cs frontend script) should be using +nadgrids conus
 > and identical setup method..? strange.
 v.out.gps[babel] -> m.proj -> cs2cs is called with "-f %.8f", which
 explains the FP quant in the second set, but the top one (ogr2ogr) changes
 at ~ %.4f or .5 (>1m)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354#comment:2>
