[GRASS-dev] nasty gotcha in alternate ogr2ogr solution comment
Markus Neteler neteler at osgeo.org
Sun Nov 2 08:47:29 EST 2008
On Sun, Nov 2, 2008 at 12:54 PM,  <svn_grass at osgeo.org> wrote:
> Author: hamish
> Date: 2008-11-02 06:54:33 -0500 (Sun, 02 Nov 2008)
> New Revision: 34139
> Modified:
>   grass/trunk/scripts/v.out.gps/v.out.gps
> Log:
> comments about nasty gotcha in alternate ogr2ogr solution (merge from devbr6)
> +#     lossy. Also that would allow ogr2ogr -a_srs $IN_PROJ -t_srs EPSG:4326
> +#     so skip m.proj pains.. if that is done ogr2ogr -a_srs MUST HAVE +wktext
> +#     with PROJ.4 terms or else the +nadgrids will be ignored! (best to feed
> +#     it g.proj -wf) in that case.
hi Hamish,
curious - what does that mean? To use ogr2ogr in conjunction with
g.proj -wf is one of my favourites... but is
GRASS 6.4.svn (latlong_tbe_climate):~ > g.proj -wf
GEOGCS["wgs84",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563],
TOWGS84[0.000,0.000,0.000]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]
sufficient to work around the indicated '+nadgrids will be ignored' problem?
thanks,
Markus
