[GRASS-dev] GRASS 6.4.0 release branch forthcoming
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Nov 3 07:15:47 EST 2008
On Mon, 3 Nov 2008, Hamish wrote:
> MN:
>> We can certainly freeze devel_grass6 and just tag RC1
>> directly from that and test it rigorously. But are we
>> sure that nobody inserts new features?
> new Vect fns req'd for v.buffer2 should be merged ASAP then.
Was the issue with the linkm library ever resolved?
> As a priority I think we can copy r.viewshed over intact,
r.viewshed still needs updating to GRASS style and conventions, e.g. there
are at least quite a lot of printf() statements - from a quick glance a
lot of these seem to be in code used for debugging and benchmarking and
there are also comments such as "only used in standalone version". Code
that is not used should be removed I feel, but it could be a lot of work.
> replace v.buffer/v.parallel/v.delaunay with "v2"s,
> replace r.watershed with r.watershed.fast (enough testing?),
> and decide others in task #344
> https://trac.osgeo.org/grass/ticket/344
> How to copy a dir from one SVN repo to the other (maintaining history)?
> Hamish
