[GRASS-dev] Simplified G_percent() output in batch jobs?
Markus Neteler neteler at osgeo.org
Wed Nov 5 03:33:35 EST 2008
On Tue, Nov 4, 2008 at 8:31 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I am running a large number of processing jobs on a
>> cluster and the job manager output is cluttered with
>> control chars from G_percent().
>> It would be great to have a switch (or detection magic)
>> to output the plain ASCII style 0..10...20.. in this cases.
>> Maybe it's already there?
> The closest is:
>        export GRASS_MESSAGE_FORMAT=gui
> That's a bit noisy, but it does eliminate the BS characters.
Right, but it's too noisy, too.
Attached a patch proposal which outputs:
export GRASS_MESSAGE_FORMAT=batch
r.slope.aspect elevation as=myaspect
2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100..
Aspect raster map <aspect> complete
Looks ok?
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20081105/55e809c9/percent_batch.obj
