[GRASS-dev] [GRASS GIS] #357: Vlib patch that provides Vect_line_get_intersections function
GRASS GIS trac at osgeo.org
Sun Nov 9 05:53:59 EST 2008
 Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  blocker      |   Milestone:  6.4.0
Component:  Vector       |     Version:  svn-develbranch6
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Attached patch provides new function Vect_line_get_intersections(), that
 is a wrapper around Vect_line_check_intersection() function.
 Vect_line_check_intersection() function not only checks for intersection,
 but also writes intersection point to line_pnts struct.
 Vect_line_get_intersections() just returns returns that struct to caller.
 Existing functionality should not be affected. If patch looks OK,  I would
 like to commit it to develbranch_6 before 6.4.0 release.
Ticket URL: <https://trac.osgeo.org/grass/ticket/357>
