[GRASS-dev] Re: [GRASS GIS] #358: new flag for r.quantile to produce output compatible with r.recode
Markus Neteler neteler at osgeo.org
Mon Nov 10 02:38:39 EST 2008
On Mon, Nov 10, 2008 at 6:38 AM, Dylan Beaudette
<dylan.beaudette at gmail.com> wrote:
>>  Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
>>      Type:  enhancement  |      Status:  new
>>  Priority:  minor        |   Milestone:  6.4.0
>>  Component:  Raster       |     Version:  svn-develbranch6
>> Resolution:               |    Keywords:  r.quantile
>>  Platform:  All          |         Cpu:  All
>> Comment (by glynn):
>>  Replying to [ticket:358 dylan]:
>>  > Small patch to re-format output from r.quantile.
>>  > Patch is attached.
>>  I've committed a modified version of this as r34219 (7.0). The behaviour
>>  is identical, but the resulting diff is a bit simpler.
> Thanks Glynn. I figured this would be universally useful. How hard
> would be it be to apply this to the 6.4 branch?
As simple as
svn merge -c 34219 https://svn.osgeo.org/grass/grass/trunk
Done.
Markus
