[GRASS-dev] [GRASS GIS] #360: v.to.db example incorrectly uses "type=area"
GRASS GIS trac at osgeo.org
Mon Nov 10 21:28:10 EST 2008
 Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  6.4.0
Component:  Docs         |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 The v.to.db description.html uses in the first example type=area
 (v.to.db map=soils type=area option=cat)
 The command line "v.to.db" help test states:
 type   Type of elements
              Type of elements (for coor valid point/centroid, for length
 valid line/boundary)
             options: point,line,boundary,centroid
 Please correct it. Thank you, Nikos
Ticket URL: <http://trac.osgeo.org/grass/ticket/360>
