[GRASS-dev] Re: [GRASS GIS] #364: Compiling QGIS from svn has a
compiler error related to GRASS api
trac at osgeo.org
Sun Nov 16 14:22:04 EST 2008
#364: Compiling QGIS from svn has a compiler error related to GRASS api
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by neteler):
A rather simple solution could be to test the version as already done in
src/plugins/grass/qgsgrassnewmapset.cpp:
#if GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR >= 4
The problem with backports is that commonly indication is lacking which
change to backport. Usually it goes well, this time it has external
impact.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/364#comment:3>
