[GRASS-dev] Re: [GRASS GIS] #361: v.mkgrid - segmentation fault
GRASS GIS trac at osgeo.org
Sun Nov 16 15:49:42 EST 2008
  Reporter:  paoloC   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Comment (by paoloC):
 Replying to [comment:3 marisn]:
 > Paolo, can You, please, compile v.mkgrid with also "-g" flag and then
 run it in gdb.
 > Also provide region information.
 If I compile with this:
 CFLAGS="-O2 -march=pentium-m -Wall -g" ./configure ...
 gdb `which v.mkgrid`
 (gdb) run  myvectgrid position=region grid=12,12 box=1,1 --o
 Starting program: /usr/local/grass-6.4.svn/bin/v.mkgrid myvectgrid
 [Thread debugging using libthread_db enabled]
 warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at 000000d4
 WARNING: 'box' option ignored with 'position=region'
 [New Thread 0xb59c1940 (LWP 8329)]
    0%
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0xb59c1940 (LWP 8329)]
 0xb799cd4b in sincos () from /usr/lib/libgdal1.5.0.so.1
 Location is a simple xy loc:
 g.region -p
 projection: 0 (x,y)
 zone:       0
 north:      12
 south:      0
 west:       0
 east:       12
 nsres:      1
 ewres:      1
 rows:       12
 cols:       12
 cells:      144
 I hope this will be useful.
 Paolo
Ticket URL: <http://trac.osgeo.org/grass/ticket/361#comment:4>
