[GRASS-dev] Re: [GRASS GIS] #365: wxGUI: ** (python:3840): WARNING **: IPP request failed with status 1280
GRASS GIS trac at osgeo.org
Sun Nov 16 18:30:56 EST 2008
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  Linux     |         Cpu:  All
Changes (by msieczka):
  * cpu:  x86-64 => All
Comment:
 Replying to [comment:1 glynn]:
 > Googling for "IPP request failed" indicates that this is generated by
 libgnomeprint polling
 > CUPS when no printer is available.
 In my case the culprit seems to be that CUPS was disabled (as I don't
 usually use any printers anyway). Once I turned CUPS service on, in spite
 of no printers configured, the warning is gone.
 > It might be possible to ensure that this doesn't occur if you don't use
 any features related
 > to printing. Unfortunately, once you do, there isn't much that we can do
 about it. glib
 > provides a mechanism to override the default logging handler, but
 neither wxWidgets nor
 > wxPython appear to use this or expose it to applications.
 So basically when CUPS is disabled/not installed on a machine, GRASS
 terminal will always be borked like this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:2>
