[GRASS-dev] raster modules still using sites library
Glynn Clements
glynn at gclements.plus.com
Tue Nov 18 16:53:56 EST 2008
Michael Barton wrote:
> For several years now, r.cost, r.drain, and now r.walk have continued
> to use the adapted sites library instead of the vector library. This
> means that they all fail if you enter vector points as starting
> points. It sure would be nice if this feature actually worked on these
> so that you could 1) use a vector map for start points rather than
> having to manually enter coordinates and 2) use multiple starting
> points.
Those modules use the sites library, but they use the G_sites_*
functions, which are wrappers around the vector library.
The functions which read legacy sites files are named G_oldsites_*,
and the only module which uses those functions is v.in.sites.
