[GRASS-dev] Re: [GRASS GIS] #365: wxGUI: ** (python:3840): WARNING
**: IPP request failed with status 1280
trac at osgeo.org
Tue Nov 18 16:59:52 EST 2008
#365: wxGUI: ** (python:3840): WARNING **: IPP request failed with status 1280
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: All
Comment (by glynn):
Replying to [comment:7 msieczka]:
> > Can you try the attached patch?
> It helps. No warnings until I select a tool from "Print display". Once I
do however, the warnings start cropping in 5 seconds intervals.
Do they stop if you select the "Reset" option?
In any case, that's all that we can do. Committed as r34380 (7.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:8>
