[GRASS-dev] Re: [GRASS GIS] #368: g.mkfontcap: extradirs=path seems
to fail
trac at osgeo.org
Tue Nov 18 17:45:44 EST 2008
#368: g.mkfontcap: extradirs=path seems to fail
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: fonts
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [comment:2 neteler]:
> What about encapsulating the extradirs parameter with
> #ifdef HAVE_FT2BUILD_H
One problem with conditional options is that the online manual should
ideally document all options, not just those which work in the specific
build of GRASS used to generate the documentation.
> or to print a related warning that no !FreeType support was compiled in?
A warning would probably be appropriate here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/368#comment:3>
