[GRASS-dev] [GRASS GIS] #370: nviz_cmd produces images with 1 pixel size
GRASS GIS trac at osgeo.org
Wed Nov 19 12:25:15 EST 2008
 Reporter:  jachym                 |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                 |      Status:  new
 Priority:  minor                  |   Milestone:
Component:  NVIZ                   |     Version:  svn-trunk
 Keywords:  commandline, nviz_cmd  |    Platform:  Linux
      Cpu:  x86-32                 |
 Testing new nviz_cmd, it produces only image of 1x1 size:
 GRASS 7.0.svn (spearfish60):~ > nviz_cmd color_map=elevation.dem
 elevation_map=elevation.dem output=image
 Loading raster map <elevation.dem at PERMANENT>...
 Translating colors from raster map <elevation.dem at PERMANENT>...
 Vertical exaggeration not given, using calculated value 1
 Viewpoint height not given, using calculated value 10561
 nviz_cmd complete. File <image.ppm> created.
 GRASS 7.0.svn (spearfish60):~ > identify image.ppm
 image.ppm PNM 1x1 1x1+0+0 DirectClass 8-bit 14b
Ticket URL: <http://trac.osgeo.org/grass/ticket/370>
