[GRASS-dev] [GRASS GIS] #373: v.generalize: hermite corrupts data
trac at osgeo.org
Thu Nov 20 12:09:23 EST 2008
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
1. import the attached shapefile
2. run v.generalize method=hermite on it
The resulting vector map renders fine in GRASS, but makes QGIS crash and
say:
qgsgrass.cpp: 374: (error_routine) error_routine (fatal = 1): BUG
(Vect_build_sidx_from_topo): node does not exist
After re-building topology the map renders fine in QGIS too. Topology dump
of the 2 maps differ like this:
Before topology re-build:
---------- TOPOLOGY DUMP ----------
N,S,E,W,T,B: 36.999861, 35.889244, -6.178626, -7.133487, 0.000000,
0.000000
Nodes (2 nodes, alive + dead ):
node = 1, n_lines = 2, xy = -7.000139, 36.999861
line = -1, type = 4, angle = -1.781112
line = 1, type = 4, angle = -0.417989
node = 2, n_lines = 1, xy = -6.662233, 36.459010
line = 2, type = 8, angle = -9.000000
Lines (2 lines, alive + dead ):
line = 1, type = 4, offset = 14 n1 = 1, n2 = 1, left/area = -1, right = 1
0.000000
line = 2, type = 8, offset = 316 n1 = 2, n2 = 2, left/area = 1, right = 0
N,S,E,W,T,B: 36.459010, 36.459010, -6.662233, -6.662233, 0.000000,
0.000000
Areas (1 areas, alive + dead ):
area = 1, n_lines = 1, n_isles = 0 centroid = 2
0.000000
line = 1
Islands (1 islands, alive + dead ):
isle = 1, n_lines = 1 area = 0
0.000000
line = -1
After topology re-build:
0.000000
Nodes (7 nodes, alive + dead ):
node = 7, n_lines = 1, xy = -6.662233, 36.459010
line = 7, type = 8, angle = -9.000000
Lines (7 lines, alive + dead ):
0.000000
line = 7, type = 8, offset = 316 n1 = 7, n2 = 7, left/area = 1, right = 0
0.000000
area = 1, n_lines = 1, n_isles = 0 centroid = 7
0.000000
line = 1
0.000000
line = -1
Ticket URL: <http://trac.osgeo.org/grass/ticket/373>
