[GRASS-dev] Re: [GDAL] #2537: gdal.Open() and ogr.Open() GRASS data
does not close projection files properly.
GDAL
trac at osgeo.org
Fri Nov 21 07:50:17 EST 2008
#2537: gdal.Open() and ogr.Open() GRASS data does not close projection files
properly.
Reporter: cgsbob | Owner: warmerdam
Type: defect | Status: closed
Priority: normal | Milestone: 1.6.0
Component: GDAL_Raster | Version: svn-trunk
Severity: critical | Resolution: fixed
Keywords: grass |
Comment (by neteler):
More precisely: r34411 and r34412 eliminate the leaks regarding "file" and
"errbuf".
Ticket URL: <http://trac.osgeo.org/gdal/ticket/2537#comment:16>
GDAL <http://trac.osgeo.org/gdal/>
Geospatial Data Abstraction Library is a translator library for raster and vector geospatial data formats.
