[GRASS-dev] r34409: Replace r.buffer with a script using r.grow.distance
Fri Nov 21 09:04:38 EST 2008
Hamish wrote:
> re. r34409: Replace r.buffer with a script using r.grow.distance
> I am wondering, does r.grow.distance do the right thing in Lat/Lon?
No.
I'll look into adding metric=geodesic, but I'm not entirely certain
that it's compatible with the algorithm.
> If not, then the C version of r.buffer still has an important advantage
> and should stay.
For now, I'll re-enable it, renamed to r.buffer2. It shouldn't be the
default, as it reads the entire map into memory.
