[GRASS-dev] Re: [GRASS GIS] #377: gis.m/Map Display fails to handle
vector layers with multiple databse layers
trac at osgeo.org
Fri Nov 21 10:35:45 EST 2008
#377: gis.m/Map Display fails to handle vector layers with multiple databse
layers
Reporter: ploewe | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Tcl | Version: 6.3.0
Resolution: | Keywords: gis.m database query
Platform: Linux | Cpu: x86-32
Comment (by mlennert):
Replying to [ticket:377 ploewe]:
> GRASS 6.3 gives strange effects when one is attempting to query or
display data from database layers greater than 1. This can be reproduced.
> Example:
> A polygon layer has been connected (in postgres) to two tables in layer
1 and layer 2:
> GRASS 6.3.0 (meteo):~ > v.db.connect -p map=counties_pie01
> Vector map <counties_pie01> is connected by:
> layer <1> table <counties_pie01> in database
<host=localhost,dbname=meteo> through driver <pg> with key <cat>
> layer <2> table <counties_pie01_a> in database
Could you give us the output of v.category option=report ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:1>
