[GRASS-dev] multi-threaded r.mapcalc
Fri Nov 21 19:34:56 EST 2008
I have added experimental multi-threading support to r.mapcalc in 7.0
(r34440). It isn't enabled by default; to enable it, use
"make USE_PTHREAD=1". It only uses a handful of pthread functions, so
there's a reasonable chance of it working on MacOSX and/or Windows
(with the pthread-win32 library).
You can change the number of worker threads by setting the WORKERS
environment variable.
The parallelism is limited to evaluation of argument expressions to
functions and operators. It doesn't attempt to calculate multiple rows
concurrently, or multiple output maps.
Also, only one thread can call get_map_row() at a time, so commands
which are I/O bound (i.e. which only perform simple calculations, so
most of the time is spent performing I/O), won't see much of an
improvement.
This is mainly due to the fact that the libgis raster I/O functions
aren't re-entrant, due to the use of pre-allocated row buffers (and
possibly other issues).
[There are also static row buffers in r.mapcalc itself, but those
could easily be eliminated if there was any point.]
Finally, eval() is excluded from parallelisation, as it is used for
variable assignments, and a variable needs to be assigned before it is
used. If this is significant, we can have separate parallel and
sequential versions. If you perform variable assignments other than in
eval(), you lose.
Mostly, I'm interested in discovering whether this actually has any
practical benefit. IOW, whether anyone is actually using scripts which
do enough computation to make use of additional cores.
