[GRASS-dev] Re: [GRASS GIS] #35: Verify and uncomment Swiss datum
parameters
trac at osgeo.org
Mon Nov 24 04:37:13 EST 2008
#35: Verify and uncomment Swiss datum parameters
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by swisstopoum):
Replying to [comment:3 msieczka]:
> Strange. Is 3 parameter transformation more accurate than the 7 one?
Answer: A 7-parameter transformation is always more accurate than a
3-parameter solution. But in the case of Switzerland it really does not
improve the situtation significantly. The residuals remain in the order of
1.5 meters if you apply the 7-parameter transform. So, it only would
complicate the calculation (sign and units of the rotations) without too
many benfits. If you want to go near the 1cm-level, the NTv2 grid (or any
other method of modelling local distortions) is the right approach.
Ticket URL: <http://trac.osgeo.org/grass/ticket/35#comment:5>
