[GRASS-dev] [GRASS GIS] #383: change fprintf to G_debug in do_proj.c
trac at osgeo.org
Tue Nov 25 20:26:27 EST 2008
Reporter: quinn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: trivial | Milestone:
Component: Raster | Version: 6.2.3
Keywords: | Platform: All
Cpu: All |
If you use r.proj to project between coordinate systems that don't
share all points, you get many errors to STDERR, for each projection
failure. I'm not sure that's necessarily an error, and I suggest the
notice be sent to G_debug.
--- grass-6.2.3.orig/lib/proj/do_proj.c
+++ grass-6.2.3/lib/proj/do_proj.c
@@ -104,8 +104,7 @@
} if (ok < 0) {
- fprintf(stderr, "pj_transform() failed\ncause: ");
- fprintf(stderr, "%s\n", pj_strerrno(ok));
+ G_debug(5,"pj_transform() failed in pj_do_proj\ncause: %s\n",
pj_strerrno(ok));
return ok;
@@ -178,8 +177,7 @@
G_free(h);
if (ok < 0) {
+ G_debug(5,"pj_transform() failed in pj_do_transform\ncause:
%s\n",pj_strerrno(ok));
return ok;
Ticket URL: <http://trac.osgeo.org/grass/ticket/383>
