[GRASS-dev] Re: [GRASS-SVN] r34603 - grass/branches/develbranch_6/vector/v.delaunay2
Fri Nov 28 18:05:28 EST 2008
Martin Landa wrote:
> Hi, sorry I am blindly run grass_indent.sh. I don't feel these changes
> to be reasonable. Reverting changes. Not sure how to fix
> grass_indent.sh.
If I run grass_indent.sh on that file (geometry.c, r34604), it doesn't
change it in any way.
Do you have a file named .indent.pro in either your home directory or
your working directory? Or is $INDENT_PROFILE set? If such a file
exists, it will add options to indent.
I've modified grass_indent.sh to add the -npro switch, to disable
reading of profile files (r34606 7.0, r34607 6.4).
Of course, the reason might be different, e.g. a different version of
indent.
