[GRASS-dev] Re: [GRASS GIS] #385: description for v.db.reconnect.all
GRASS GIS trac at osgeo.org
Sun Nov 30 01:05:28 EST 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:5 hamish]:
 > Replying to [comment:4 glynn]:
 > > I've just put it back to "Name of old database". Notes, details,
 > > caveats and the like belong in the manual.
 > (if it belongs in the manual please move it into the manual
 > instead of just deleting it)
 clearer- you didn't actually "put it back" ie revert r34627, you changed
 it.
 AFAICT Nikos's patch reduces to:
 The name of '''old_database''' needs to be the exact string
 which appears as the fourth field printed by 'v.db.connect -g',
 i.e. with substituted variables.
 does that mean you need to use the full path not $MAPSET/... ?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/385#comment:6>
