[GRASS-dev] Re: [GRASS GIS] #295: region corrupted
trac at osgeo.org
Sun Nov 30 21:03:39 EST 2008
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
All that has happened here is that 'g.region -a' has been run by the GUI,
which "snaps to the grid".
n-s is the same in both of your cases, but in the second case n,s is
exactly divisible by the nsres. (give or take 2e-6 error introduced by
g.region outputting to terminal using %f; internally the double prec FP
variables will equate)
By default if there is a conflict g.region respects the region bounds over
the resolution (I would guess this reduces >90deg LL problems and is the
less risky solution in the original GRASS military context!). With the -a
flag the resolution ''grid'' is respected over the bounds and the bounds
are "snapped" to the resolution grid with origin 0,0.
this causes an interesting problem,
G> g.region n=100525 s=100475 w=500825 e=500875 res=50 -g
n=100525
s=100475
w=500825
e=500875
nsres=50
ewres=50
rows=1
cols=1
cells=1
G> r.mapcalc one=1
G> g.region res=50 -a -g
n=100550
s=100450
w=500800
e=500900
nsres=50
ewres=50
rows=2
cols=2
cells=4
G> d.rast one
G> d.grid 25
note that g.region rounds outwards, and that resampling shifts the cell to
the N and W by 1/2 a cell. In these cases my work around solution has been
to half the resolution,
{{{ g.region res=25 -ag }}}
then no resampling shift occurs by careless user mistake.
You ran:
3. In wxGUI: "Set computational region from display"
so you can expect the region to change.
If there is a problem it is that the
{{{ g.region n=100525 s=100475 w=500825 e=500875 res=50 -g }}}
case may? be resamped by the GUI into the attached "after -a" image.
I haven't checked that. But if you know about the resampling issue (I
believe there's a paragraph about it in the g.region help page), this
problem is easily worked around, and much less painful than having -a as
the default. (IMO to switch that would be a horrible mistake)
fwiw, screenshots created with xmons+d.out.file, not from the GUI.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/295#comment:5>
