[GRASS-dev] [GRASS GIS] #317: WinGRASS MSYS Console doesn't run correctly
GRASS GIS trac at osgeo.org
Wed Oct 1 11:11:45 EDT 2008
 Reporter:  gislab        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect        |      Status:  new
 Priority:  major         |   Milestone:  6.4.0
Component:  default       |     Version:  unspecified
 Keywords:  msys console  |    Platform:  MSWindows XP
      Cpu:  x86-32        |
 1. Install GRASS in C:\GRASS
 2. Check C:\GRASS\msys\home\, in this folder C\Documents and
 Settings\MYNAME is created during install, where grass63 is sitting.
 3. Run Start\Programs\GRASS\GRASS MSYS Console
 4. Check C:\Gis\GRASS\msys\home\ again, now in this folder MYNAME
 (lowercase) folder is created, without grass63 file in it.
 Needless to say, that even if I move grass63 from the folder made
 right after install
 "C:\GRASS\msys\home\C\Documents and Settings\MYNAME"
 to the one created on first run of MSYS
 "C:\GRASS\msys\home\MYNAME"
 GRASS GUI starts with error messages, grass63 -text doesn't start at all,
 producing "Redirection is not supported" message.
 Removing .grassrc6 from C:\GRASS\msys\home\C\Documents and
 Settings\USERNAME\
 and .grassrc6 from C:\Documents and Settings\USERNAME\
 doesn't help.
 The problem was replicated on at least 4 more machines by other
 people under the same operating system and grass version.
 http://lists.osgeo.org/pipermail/grass-windows/2008-September/001502.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/317>
