[GRASS-dev] Re: new version of lib/linkm (linked list memory manager)
Sat Oct 4 21:16:10 EDT 2008
Rosen Matev wrote:
> > I've written a new version of lib/linkm. It's interface is pretty much
> > the same. Names of functions, variables and the module itself are
> > subject to revision, as well as the documentation is (my English is
> > not that good). I've done some testing, the lib works correctly and
> > outperforms conventional linked list 4 to 12 times. Read the
> > documentation in linked_list.c for more info.
> > I'm looking forward to incorporating this into GRASS, since lists are
> > needed in Vect_get_point_in_poly() and the current library is buggy.
> > Here is what I've written.
> I really need some help to integrate this one into trunk. The current
> module prevents Vect_get_point_in_poly() from working correctly in
> some unusual cases.
So are you going to modify your code to match the existing linkm
library, or modify the vector and bitmap libraries to use the new
interface?
