On Sun, Oct 5, 2008 at 9:39 PM, Glynn Clements <glynn at gclements.plus.com> wrote: > r.out.gdal.sh is still installed, but hasn't been converted. Is this > worth keeping around as a backup? If it is, I'll convert it, otherwise > it should be removed. It should be removed as incomplete + causing troubles. Markus
