[GRASS-dev] isnan() in i.atcorr
Hamish
hamish_b at yahoo.com
Mon Oct 6 21:52:01 EDT 2008
Paul Kelly wrote:
> i.atcorr uses the isnan() function which seems to cause
> compilation to fail on Windows:
> main.cpp includes <cmath>; I wonder if the problem is
> due to the fact isnan() is a C99 function? Should it be changed?
if it helps, there is a is_nan() in r.in.mat/main.c:
int is_nan(void *p, RASTER_MAP_TYPE dtype)
/* fn to test if incoming data point is either a IEEE NaN or a GRASS CELL null
* Takes a value of type RASTER_MAP_TYPE stored at memory address "p"
* Returns 1 if we think it is a null, 0 otherwise
/* please improve */
it uses the 'if(a != a)' method.
Hamish
