[GRASS-dev] nasty export of doubles
Glynn Clements
glynn at gclements.plus.com
Wed Oct 8 03:36:18 EDT 2008
Hamish wrote:
> this change
> http://trac.osgeo.org/grass/changeset/31236
> introduced an unfortunate problem, whereas imported doubles have their
> system level precision exposed (%.14f).
> the general goal is that upon presentation by d.what.vect, v.db.select, or
> whatever trailing 0s are nicely snipped away ala G_trim_decimal(); and
> more over that in reasonable cases input == output. That's a reassuring
> that the rest of the internals are ok, otherwise it is hard to spot when
> something has gone wrong.
> compare input:
> cat|station|sounder_m|lat|lon|easting|northing
> 1|DC|94.3|-45°27.4492'|167°09.2427'|2053056.83|5511584.74
> 2|CA|86.4|-45°24.2306'|166°59.0481'|2039364.05|5516567.25
> 3|MR|407|-45°18.6105'|166°57.9204'|2037128.89|5526840.51
> 4|BA|167.6|-45°33.5942'|166°54.6907'|2034985.01|5498850.4
> 5|SC|168.2|-45°43.6784'|166°55.8538'|2037880.75|5480334.83
> 6|LS|365.9|-45°59.0538'|166°48.5873'|2030638.43|5451227.37
> with old lib/db/dbmi_base/valuefmt.c (%lf) output via v.db.select:
> (they're identical)
> and then with the current valuefmt.c (%.14f) output:
> 1|DC|94.3|-45°27.4492'|167°09.2427'|2053056.83000000007451|5511584.74000000022352
> 2|CA|86.40000000000001|-45°24.2306'|166°59.0481'|2039364.05000000004657|5516567.25
> 3|MR|407|-45°18.6105'|166°57.9204'|2037128.88999999989755|5526840.50999999977648
> 4|BA|167.59999999999999|-45°33.5942'|166°54.6907'|2034985.01000000000931|5498850.40000000037253
> 5|SC|168.19999999999999|-45°43.6784'|166°55.8538'|2037880.75|5480334.83000000007451
> 6|LS|365.89999999999998|-45°59.0538'|166°48.5873'|2030638.42999999993481|5451227.37000000011176
> but if we use %lf, beyond %.6f would be rounded/truncated??
Yep.
> As demonstrated by northing 5498850.40000000037253 above, using %.14f
> just guarantees 14 numbers after the ".", not add any more significant
> digits.
> so, given that projected coordinates in the range of millions, to 3
> decimal places (mm), will be common -- how to tell the string to be
> a max of 15 digits total, not assume some fixed number AFTER the "."
> will cover it? is there some %15.15f or so?
Nope. The closest is %.15g, which will use up to 15 significant digits
(use %#.15g to avoid stripping trailing zeroes), but it will use
exponential notation if the exponent is greater than or equal to the
precision (15 in this case) or less than -4.
If you want a fixed number of significant digits and no exponential
notation, you have to do it yourself, e.g. use %.100f and take the
first N characters or everything up to the decimal point, whichever is
longer.
> In the past we tried %g there, but it was not suitable because the
> easting/northing would jump into e+06, which is no good. (and
> v.in.ascii created db tables will usually include easting and
> northings)
If you use a larger precision, the exponent at which it switches to
exponential notation will increase accordingly. For coordinates, %.8g
will be sufficient, but values very close to zero (less than 0.1mm)
will still use exponential notation).
> I don't know if there is a "right" answer here, my vote would be to
> go back to %lf as the lesser of the two evils.
Too much precision is ugly. Too little precision makes it impossible
to use small values. A general-purpose conversion routine such as this
needs to handle the full range of floating-point values, which
basically means %.15g.
If you want neater output, the module needs to perform its own
formatting based upon the expected range of the data. The module knows
what the values represent, the DBMI library doesn't.
> again, this is about exposed numbers (to a DB or ascii), not
> internally stored doubles for calculation, and I'd expect the
> current %.14f to mislead some SQL (where FOO > 10.0) style query
> sooner rather than later.
> related; this change looks more reasonable:
> http://trac.osgeo.org/grass/changeset/25355
Yeah, but in that situation, you know that the values are coordinates,
so you know the approximate range and precision of the values.
FP values stored in a database don't have to be coordinates. In fact,
they probably *aren't* coordinates.
