[GRASS-dev] Re: [GRASS-user] How to write scripts in GRASS
Hamish
hamish_b at yahoo.com
Wed Oct 8 20:56:28 EDT 2008
Glynn wrote:
> 6.4 and 7.0 include a Python module (named "grass") which provides
> various utility functions for writing GRASS scripts in Python.
> The best available documentation for this module is the code itself
> (lib/python/grass.py in 6.4 and 7.0) and the scripts which use it
> (scripts/*/*.py, currently only in 7.0). There is also a README file
> (lib/python/README.txt).
I've just had a glance at that README, and it seems rather clear to me
that the file would better be incorporated as Doxygen comments in the .py
file.
http://www.stack.nl/~dimitri/doxygen/docblocks.html#pythonblocks
"Since python looks more like Java than like C or C++, you should set OPTMIZE_OUTPUT_JAVA to YES in the config file."
Hamish
