[GRASS-dev] Re: vdigit working on Mac mostly
Michael Barton
michael.barton at asu.edu
Thu Oct 9 02:29:23 EDT 2008
On Oct 8, 2008, at 11:08 PM, Martin Landa wrote:
> Hi,
> 2008/10/9 Michael Barton <michael.barton at asu.edu>:
>> There used to be a combo box on the left of the digitizer tool bar
>> that
>> allowed selection of the map to digitize (or to create a new map).
>> This has
>> disappeared. Has it been removed or is it just not showing up?
>> There was an
>> earlier problem with combo boxes in Mac toolbars. I thought it was
>> fixed,
>> but maybe it's back. There is a workaround (used for the combo box
>> in the
>> main display toolbar).
> no, the combobox in vdigit toolbar hasn't been removed. Seems to be a
> bug in Mac wxPython. Can you see combobox in map toolbar?
I went ahead and applied the Mac fix for the missing combo box to
develbranch_6. Could you check to see if it works OK for you? Thanks.
Back to work.
Michael
