[GRASS-dev] Re: [GRASS GIS] #123: r.in.xyz: import bug when using
scanned extent
trac at osgeo.org
Thu Oct 9 21:40:48 EDT 2008
#123: r.in.xyz: import bug when using scanned extent
Reporter: neteler | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
* platform: => Unspecified
* cpu: => Unspecified
Comment:
I'll have a look at r.in.xyz to see if we can change the < to <= ''if we
are on the last pass block'' without harming module speed much.
If we do it for all passes there will be duplicated cells for points which
fall exactly on pass block borders.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/123#comment:8>
