[GRASS-dev] Re: [GRASS GIS] #326: g.findfile element=colr2
GRASS GIS trac at osgeo.org
Fri Oct 10 03:39:36 EDT 2008
  Reporter:  martinl      |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  closed
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-develbranch6
Resolution:  invalid      |    Keywords:  colr2, color table
  Platform:  All          |         Cpu:  All
Changes (by martinl):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:1 glynn]:
 $ eval `g.findfile element=cell file=elevation.dem`
 $ eval `g.findfile element=colr2/$mapset file=elevation.dem`
 $ echo "$file"
 /opt/grass-data/spearfish57/glynn/colr2/PERMANENT/elevation.dem
 Ops, I have overlooked this possibility... Thanks for pointing it out.
 > BTW, why would you be using g.findfile to locate colour tables in the
 first place?
 > You shouldn't normally need to know whether a map gets its colour table
 from colr, colr2, or uses the default rainbow table.
 It's used in wxGUI colorrules.py module for "replace current color table"
 check.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/326#comment:2>
